2200 is not better than stock. I would at least get 2600 stall. But only a good converter builder can tell you what you need.
in a street some guy said that the car doesn’t move until the engine raises the 3000 rpm of course it have a 3000 stall TC
This is a good example of a cheap converter. Just because the car has a stall of 3000 it should move long before 3000stall.
Normal driving conditions should not change at all. Only when you mash the gas it should flash the rpms to the desired stall.
I have owned many converters for several different cars and brands. I first installed a Lentech in a 93 stang. Damn I loved that car but sold it later in life. I ran a best of 13.9 in the 1/4 with only a lentech AOD and converter in the car no other mods at all.
Next time around with a different mustang I went with a company that is no longer in business named GER, Man did they steal some money from me. The only reason I went with them in because they had adds posted all of mustang magazines. They were also a lot cheaper than Lentech prices that I paid for before. I learned my lesson with them.
Their converter acted like the one you mentioned above. It was a 3000 stall but would not move the car at all till I got the rpms to 3000 even when cruising around.
After that crap I made the switch to 5-speed and haven't looked back.
3-years ago I purchased a 71 dodge dart which put me back into the automatic world. Dodge makes a pretty stout 727 trans. It came with a B&M 3000 stall. Now it was a lot better acting than the GER, but B&M only sells standard stuff, nothing is custom to your car. Ten different people may have that same converter in each car with a different combo. Does that make sense at all? How would the same converter work on ten different cars that make all different power?
So with my history of this problem I did major research on what to get this time around. The path led me to a man called Frank Lupo and his company Dynamic conv. They are pricey to I paid about 700$ for a 9" 3800 stall converter. Now this thing rocks. Best converter by far I will ever own. This thing doesn't act any different taking off slow than you stock converter in you stang. But man slam the gas and BOOM 3800 tire spinning power rpms is on tap. The 727 is only a 3-speed like the C4, On the highway I can do about 55-60 at 3000rpms with
4:30 gears in the rear with the converter. That is Better than the B&M was on the highway it was around 3500 at 60 with the same gears.
Now I would tell you to go nowhere but to see frank or Shawn at dynamic but I don’t thing they offer a converter for the AOD. So my next advise would be Lentech. Nobody knows the AOD like Lentech does.
try tcsproducts dot com, I believe they build for lentech. very high quality.
I thought Lentech built all their own stuff in house, but I could be wrong.
Now even a popular name for AOD is precision Industries, but I have never dealt with them.
Here are some links to all above mentioned:
Lentech
http://www.lentechautomatics.com/aodproducts.html
Frank Lupo's Dynamic Converters
www.dynamicconverters.com
Dynamic Transmissions
http://www.dynamicracingtrans.com/tctconverters.htm
Precision Industries
http://www.converter.com/stallion.htm
