SO I decided to clean the engine up a little more on my notch over the winter… I have now been trying to get the stupid thing to run right for the past week.
I removed the egr, smog pump, tube behind the heads, TAP/TAD solenoids, cruise control
I also had the upper intake off the car. Put everything back together (turned the egr off with my tweecer) and the car is running like crap!!
I removed all the smog vacuum lines and plugged them, removed the egr spacer, and installed covers on the back of the heads….. whats going on???
If it decides to start it will rev right up to 2000rpm and just sit there… then it will fall to 1000, then to 500, then the car will want to die and catch itself and go back up to 2000. I just drove it around the block and its bucking and just running crappy. Anyone have any ideas that I could look into that I have missed?
