tough steering question
66coupe306
32
I have a 66 8cyl w/ manual steering and drums. I am in the process of installing a supercharger, disc brakes and power steering. I have some 67 steering parts ie control valve, center link. A new 99 sable ps pump W/ remote reservoir and granada brakes. Here is the question, what is the difference between 67 and 66 power steering linkages. Are the lengths different or the ball ends different size? What I want to do is use the 67 center link and control valve then get new inner and outer tie rods. A 66 has two different outer ends and require a special end or adapter to use the granada spindles, does a 67?
Thanks,
justin
the 67 center link is too wide to use on the 66 mustang. you will have severe bump steer if you try to use it. find a maverick with power steering and use the center link off that car.
