  • 2.3L (N/A & Turbo) Tech
TP sensor
  • Thread starter Thread starter 93-2.3
  • Start date Start date May 13, 2005
9
93-2.3
99
PA
May 13, 2005
  • May 13, 2005
whats all involved in replacing my tps on a 93 mustang 2.3 to me it looks like i need to remove my throttle body just wondering
Keasbey
915
Montreal
May 13, 2005
  • May 13, 2005
you don't need to... Just remove the 2 screw on the TPS and voila!
9
93-2.3
99
PA
May 13, 2005
  • May 13, 2005
ok looks like a real tight fit almost like my egr is in the way and like the iac would be in the way to. but thank you for the input.... do i need to calibrate the tps or anything like that? or does it just drop back in?
Keasbey
915
Montreal
May 13, 2005
  • May 13, 2005
You will need to calibrate it, at .94-1V at idle, or just make a "mark" near the screw, just to remember where it was..
9
93-2.3
99
PA
May 13, 2005
  • May 13, 2005
how would i read that my buddy has a snap on scanner but it dont give me the status for sensor output so im assuming a volt meter but what wires would i tap in to
HyYoSilver
1,339
On a creeper, underneath the car
May 13, 2005
  • May 13, 2005
There's three wires going to the TPS. One is the ground wire, one is a 5v reference, and the other is the signal wire. (Use a straight pin to backprobe the wires at the connector. Take readings off the pin). The signal wire is the one used for adjustment; it'll have less than one volt at idle with the key on.
A good TPS will have a smooth transition from (about) 1v-4v, on the signal wire, when the throttle is advanced. If voltage is erratic or spikes, then the TPS is bad.
Engine 95 GT and 95 Cobra sensors and TB gasket
  • Sonic
  • Dec 21, 2025
  • 1994 - 1995 Specific Tech
1994 - 1995 Specific Tech Dec 23, 2025
WhiteCobra95
Engine Fuel not pumping
  • Creomod
  • Apr 13, 2026
  • 2 3
Fox 5.0 Mustang Tech Jul 22, 2026
Resolved 1985 3.8 tbi, Only starts with fluid then runs great
  • broomtail78064
  • Jul 12, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jul 28, 2025
AeroCoupe
9
New from northern MN
  • 91firecracker
  • Apr 19, 2026
  • The Welcome Wagon
The Welcome Wagon Apr 19, 2026
Body plugs and cleaning
  • bdub_mkg
  • Feb 10, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Feb 11, 2026
bdub_mkg
