Okay, I've got the throttle body adjusted for idle at 900 rpms with the IAC disconnected. I'm putting a new TPS sensor on tomorrow and I'm kinda confused if the voltage needs to be set at .999v where the TB is set at now or with the butterfly fully closed.
I'm kinda thinking that wouldn't make sense because with the blade fully closed and the TPS set at .999 volts... adjusting it later would raise the voltage well over 1 volt.
I feel like I could be wrong thou. Can anybody set me straight on this?
