TPS bad?
  • Thread starter Thread starter MahFiVeOh
  • Start date Start date Sep 18, 2007
MahFiVeOh
531
9
49
Ontario, Canada
Sep 18, 2007
  • Sep 18, 2007
How do you know if your TPS is bad?? The reason i ask is because i reset mine on the w/e to .98-.99 (it was at .88 previously)and my car seems to studder when accelerating slowly.I'm not sure if this is just coincidence or what.One thing i did notice is that the black wire seems to be exposed as if its been pulled out of the actual sensor.
HISSIN50
34
129
Sep 18, 2007
  • Sep 18, 2007
Check the wire you think is bad. You should see the meter reading change during a wiggle test if it's corrupted.
In general, I'd have left the TPS alone - you were real close to the optimal reading anyhow. I wont debate the ratcheting ability vs people who want to set the TPS to a given static reading. In general, I don't recommend touching the TPS unless it spits a code, has a wiper issue or is touched to deal with a surging issue.
MHO.
Good luck.
Engine Rough idle and aggressive sputtering when accelerating
  • 88vertible
  • Aug 13, 2025
Fox 5.0 Mustang Tech Dec 13, 2025
Jarhead67
J
Engine Strange Noise
  • burntokita
  • May 8, 2026
Fox 5.0 Mustang Tech May 11, 2026
keel
Fox '87 GT can't get to stay running
  • spilly
  • Mar 29, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 20, 2026
spilly
  • Gulftown980x
  • Jul 29, 2026
  • SN95 4.6L Mustang Tech
squeak93
H
Ongoing Battle With Hydraulic Lifters
  • hailer06
  • Jun 8, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 9, 2026
