R raginbul469 Founding Member Oct 23, 2001 160 0 0 michigan Jul 30, 2005 #1 Jul 30, 2005 #1 i was setting my TPS the other day and i noticed at WOT it only register 4V. should i buy a new sensor or is this acceptable?
Saleen8786 New Member Oct 7, 2003 209 0 0 Marlton, NJ Jul 30, 2005 #2 Jul 30, 2005 #2 dont know, but check the tps itself sometimes it gets gunked up with s hit, mine had to be changed cus it had all kinds of gunk(black clumps jammin it up)
HISSIN50 "How long does it take to get help in here? 15 Year Member Nov 29, 1999 31,179 34 129 Jul 30, 2005 #3 Jul 30, 2005 #3 I would check the VRef and ground to the TPS. A bad ground will diminish the return signal. The puter goes to WOT at 3.7 volts, but I dont think I would want the sensor being that out of whack. Also, what does it read baseline? Good luck.
R raginbul469 Founding Member Oct 23, 2001 160 0 0 michigan Jul 31, 2005 #4 Jul 31, 2005 #4 i have it set at .98-99 at idle and WOT maxes at 4.0. from what i read i thought that it was wuppost to max at 5 volt or is that just the input?
Z zeusmoto New Member Feb 15, 2004 390 0 0 utah Jul 31, 2005 #5 Jul 31, 2005 #5 what kind of device do you use when calibrating your tps and how do i connect it
R raginbul469 Founding Member Oct 23, 2001 160 0 0 michigan Jul 31, 2005 #6 Jul 31, 2005 #6 just use a digital multi-meter set it to DCV ( direct current voltage)
HISSIN50 "How long does it take to get help in here? 15 Year Member Nov 29, 1999 31,179 34 129 Jul 31, 2005 #7 Jul 31, 2005 #7 Here is some info.
