95GTV8 said:
Does TPS only effect idle issues, or does it effect overall drivability and horsepower etc?
RacEoHolic330 said:
Yea. I'm actually having some TPS issues right now. I have it set at .99v at idle and it reads 4.66 at WOT, but when I put the throttle to the floor, my PMS only shows 98-99%, its pissing me off. Maybe I need a new TPS.
The PMS is pretty dumb when it comes to the TPS. But, it doesn't make any real difference.
For
all Mustangs with EFI from the factory, the TPS is
zeroed out at start up. That *includes* the SD EEC-IV's. Most Stang EEC's set WOT at ~2.7 volts over the
turn-on voltage of the TPS.
The main purpose of the TPS, in normal driving, is to add "accelerator pump" or the dash-pot function when there is a "quick" change in the throttle. The MAF (vacuum for SD) is slow to respond, and the O2's are super slow. So, the EEC uses the
rate of change of the TPS along with the RPM to "estimate" the proper amount of additional/reduced fuel for the desired A/F ratio.
When the MAF (vacuum for SD) catches up, the EEC can _better estimate_ the desired injector pulse width for the desired A/F. However, it's really the O2's that determine a ton of stuff.
At WOT, the EEC uses the trim, the MAF output (vacuum & RPM for SD), and special WOT tables to calculate the fuel. Of course, those tables are often set to be on the _rich_ side in order to prevent pre-detonation. But, being too rich does cost HP. So, some tuners can adjust those WOT tables for
your specific engine and set up and get you "a few more HP".
