TPS question
  • Thread starter Thread starter shallto
  • Start date Start date May 29, 2006
shallto
464
OBX, NC
May 29, 2006
  • May 29, 2006
I have a Zex nitrous system and haven't filled the bottle lately. I filled it the other day but the nitrous solenoid isn't opening . I tried setting TPS. I can set the idle voltage to .995 but it only goes to 4.5 at WOT. Do you think this is a TPS problem or a solenoid problem?
vristang
4,933
101
124
Seattle
May 29, 2006
  • May 29, 2006
Your TPS sounds normal.
Even though the tps uses Reference Voltage (0-5v) it seems that the tps output never hits a full 5 volt.
4.5v -4.7v seems normal.
I know very little about nitrous though.
jason
L
luckythirteen13
648
Anaheim, CA
May 29, 2006
  • May 29, 2006
find a 5v source in your car and hook the solinoid directly to it to test and see if it is working correctly. if it doesnt then you know its the solinoid. make sure there is no n2o in the line while you do it
JimBowy
330
Downriver, Mi
May 29, 2006
  • May 29, 2006
i've tested 3 TPS modules, most max out around 4.66
F
facemelter71
60
cincy
May 29, 2006
  • May 29, 2006
zex nitrous systems program themselves to the tps voltage.now i dont have a nitrous kit but have read alot about them.i think if you unhook the module to the zex kit and reinstall it youll have to reprogram your tps voltage so even if it is a little low itll still opp the noid.
Running very very rich
  • 2esoteric
  • Oct 31, 2025
Fox 5.0 Mustang Tech Oct 31, 2025
Need some camshaft guru advice on power loss from supercharger to nitrous
  • TTSaleen
  • Dec 1, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Dec 29, 2025
revhead347
Engine Stalls when downshifting/coasting
  • Scott_S
  • Nov 5, 2025
Fox 5.0 Mustang Tech Nov 6, 2025
Mustang5L5
Engine Rough idle and aggressive sputtering when accelerating
  • 88vertible
  • Aug 13, 2025
Fox 5.0 Mustang Tech Dec 13, 2025
Jarhead67
J
SURGING IDLE / NO IDLE CHECKLIST FOR 1996–1998 MUSTANG GT (4.6L 2V) - Work In Progress
  • Noobz347
  • Aug 30, 2025
1996 - 2004 SN95 Mustang -General/Talk- Aug 30, 2025
