TPS Replacement
AxlsDemocracy
50
Has anyone replaced their TPS before? I need to replace mine and I am stumped. LOL I read online that all I need to do is unscrew it and replace it, but due to its location, I can't screw :owned: ....How do I take this damn thing off?
It'd be a hell of a lot easier if you took the throttle body off. When you go to take the TPS off, make sure you soak the screws in some PB Blaster or Liquid Wrench or the like, they're in REAL tight. If you still can't get them out (since you mentioned you're replacing it) then you can just drill straight through the screw and pull it off that way. That's what I did when I swapped throttle bodys. Good luck
Foxes baseline also, but with all the idle surging issues both cars have, it does not hurt to check the TPS setting at a minimum.
Take off the IAC valve, and you will have access. Or take off TB completely.
either way, when you are ready to replace it, get replace the damn phillips head screws with hex head screws. that will save any future annoyances and help you in adjusting TPS voltage at idle.
YOu want to be around .90 - 1.1V at idle and somewhere in the range of 4.66V at WOT. The car does not need to be running to do this, only key in acc.
Scott
I second that those screws are in tighter than ****! I put my TB in a vise to hold it and tried every method possible using a simple screwdriver, and just didn't have enough force to get it. Then I tried to use one of the screwdrivers you hit with a hammer and it back screws out (no clue what you call it) and broke the ear off of the TPS! Its amazing how easy the screw came out after that. Anyways, it cost about $50 from Ford, so be careful and definitely use some penetrating oil, I probably would have gotten mine out if I took more time and wasn't being impatient.
Impact driver. Very useful tool to have on hand. The bits are hardened and you can use a lot of torque with the large grip surface. Anyone who pulls bowls off bike carbs has probably had to use one (or vice grips on the side of the head of the screw) since the pot metal screws seize into the carb.
yea you can rotate the IAC by taking off one bolt then you can get at the TPS.
But I found out down the road its easy as hell to take off the entire TB. Just do it that way.
Drill out your TPS holes to about 2x the size that way you can get a good reading.
