  • SN95 4.6L Mustang Tech
TPS sensor problem
  • Thread starter Thread starter invertmast
  • Start date Start date Dec 31, 2005
invertmast
379
North Port, FL
Dec 31, 2005
  • Dec 31, 2005
Ok,
i got bored and decided to checkout the TPS sensor that was mentioned in my last thread.. I followed my hanes manual about checking it, but i found something a little weird.. The hanes manual said.
With the car at idle, the voltage between the ground and sig. wire should be between .5 and 1.0 volts..
And as the gas pedal is pressed, it should increase to about 4.0-5.0 volts when at WOT.
Well.. here's the deal.
My car when at ideal has. 4.2 volts between the ground and signal wires.
and at WOT has between .5 and 1.0 volts. I can't remember from my Ford tech days if this is right or not (learned too much crap sense then), or if hanes just got them backwards.
What do all you guys say?
L
Electrical problems with passenger side downstream o2 sensor
  • Lexiii12
  • Sep 14, 2026
2005 - 2014 S-197 Mustang -General/Talk- Sep 14, 2026
Lexiii12
L
Electrical Stumped No Start...
  • sydhawk
  • Oct 28, 2025
Fox 5.0 Mustang Tech Oct 29, 2025
sydhawk
G
2006 Mustang GT o2 Sensor Wiring Issue Car Bogging/Choking
  • GCantero93
  • Sep 5, 2025
  • 2005 - 2009 Specific Tech
2005 - 2009 Specific Tech Sep 6, 2025
SURGING IDLE / NO IDLE CHECKLIST FOR 1996–1998 MUSTANG GT (4.6L 2V) - Work In Progress
  • Noobz347
  • Aug 30, 2025
1996 - 2004 SN95 Mustang -General/Talk- Aug 30, 2025
R
93 LX 2.3 Trouble codes 53, 85, 21 help
  • Rickshaw302
  • Apr 15, 2025
  • 2.3L (N/A & Turbo) Tech
2.3L (N/A & Turbo) Tech Apr 18, 2025
AeroCoupe
