  • 1994 - 1995 Specific Tech
TPS setting
  • Thread starter Thread starter green_drop
  • Start date Start date Sep 8, 2004
G
green_drop
43
  • Sep 8, 2004
I am trying to get rid of my hanging idle problem and a buddy had a similar problem and dropped his tps voltage to .977 mine was at .990. I tried dropping it to .977 and still i get a hanging idel it takes forever for my car to come to an idle. I was wondering if anyone has a good understanding on what the TPS voltage should be. This is what is done to my car. 1995 Mustang GT vert.
-Ford Motor sports 4.10 rearend gear
-BBK shorty equal length headers
-bassani x-pipe with cats
-mac 2.5 cat-back exhaust
-jegster upper and lower control arms
-kyb gas-a-just shocks and struts
-gms subframe connectors
-FMS aluminum driveshaft
-Tremec TKO 5-speed transmission
-mac cold air intake
-FMS 65mm Throttle body
-Trickflow upper and lower intake
-Nitrous Express 150 shot wet kit
-Nitrous Express purge kit
-275/40R17 nitto drag radials in back
-245/45r17 BFgoodrich comp T/A in front
-Aeromotive fuel pressure regulator
-Aeromotive 255lph intank fuel pump
-Jacobs Fire control ignition system
-NGK spark plugs
-180 degree thermostat
-smog pump taken off
-Trickflow twisted wedge heads
-Gaskets port matched from heads to intake
-FMS Hardened push rods
-E-303 Cam
-Ford racing 1.6 roller rockers
-GMS 75mm mass air calib for 30lbs injectors
-Aeromotive adjustable fuel pressure regulator
-ford racing 30lbs injectors
-Ford racing roller timing chain
only 272rwhp. w/o nitrous. 360rwhp with nitrous with a NX 150hp wet shot.
Any suggestions on how to make it 300rwhp on motor. I am thinking a chip.
Silver85TC
130
  • Sep 8, 2004
You haven't ever done a search on this topic, have you.
Check this thread just 4 days ago;
http://forums.stangnet.com/showthread.php?t=498627
Do a search.....all your questions about the TPS for the 94/95 5.0 will be answered in 5 minutes.
With regards to your hanging idle.......remove and clean the snot of the IAB valve with TB cleaner. Replace your ECT/ACT sensor's if they are old. Their output starts to become wonky when they get old which can cause idle problems (and no, they may not set off a CEL). Make sure that the two sensor wires inside your MAF meter are clean. Check for vacuum leaks. Check for exhaust leaks. After you've done all that, unplug the battery to reset the PCM.
If everything above checks out, then you may just have to accept the fact that you're idle is not going to be great with the mods you have done. Some people have had good success using tweaker to get their idle under control with H/C/I mods.
Longtube headers and an offroad H pipe would help.
Cheers
stangla2
90
  • Sep 8, 2004
your best bet is to get a "chip" ie Autologic, that should take care of the problem
slytherin
702
northeast ohio
Sep 8, 2004
  • Sep 8, 2004
I have my voltage set at .928 and it still hangs for a split second when at running temp then it's fine.
Forced Induction Prepping for supercharger on non-stock build
  • 91fox427
  • Nov 25, 2025
Fox 5.0 Mustang Tech Jan 5, 2026
Qtrhrse23
  • dan50
  • Jul 18, 2026
dan50
SURGING IDLE / NO IDLE CHECKLIST FOR 1996–1998 MUSTANG GT (4.6L 2V) - Work In Progress
  • Noobz347
  • Aug 30, 2025
1996 - 2004 SN95 Mustang -General/Talk- Aug 30, 2025
SOLD For Sale '92 LX Street/Drag car - WV
  • MikeyMustang
  • Apr 12, 2025
2K
Fox Body Mustangs For Sale (1979-93) Dec 31, 2025
MikeyMustang
Fuel ‘88 GT Runs Rich Cold — Fixes Itself When I Unplug Sensors (ECT, MAF, O2, etc.)
  • Sufarry
  • Nov 6, 2025
Fox 5.0 Mustang Tech Nov 9, 2025
Mustang5L5
