TPS setting
green_drop
43
I am trying to get rid of my hanging idle problem and a buddy had a similar problem and dropped his tps voltage to .977 mine was at .990. I tried dropping it to .977 and still i get a hanging idel it takes forever for my car to come to an idle. I was wondering if anyone has a good understanding on what the TPS voltage should be. This is what is done to my car. 1995 Mustang GT vert.
-Ford Motor sports 4.10 rearend gear
-BBK shorty equal length headers
-bassani x-pipe with cats
-mac 2.5 cat-back exhaust
-jegster upper and lower control arms
-kyb gas-a-just shocks and struts
-gms subframe connectors
-FMS aluminum driveshaft
-Tremec TKO 5-speed transmission
-mac cold air intake
-FMS 65mm Throttle body
-Trickflow upper and lower intake
-Nitrous Express 150 shot wet kit
-Nitrous Express purge kit
-275/40R17 nitto drag radials in back
-245/45r17 BFgoodrich comp T/A in front
-Aeromotive fuel pressure regulator
-Aeromotive 255lph intank fuel pump
-Jacobs Fire control ignition system
-NGK spark plugs
-180 degree thermostat
-smog pump taken off
-Trickflow twisted wedge heads
-Gaskets port matched from heads to intake
-FMS Hardened push rods
-E-303 Cam
-Ford racing 1.6 roller rockers
-GMS 75mm mass air calib for 30lbs injectors
-Aeromotive adjustable fuel pressure regulator
-ford racing 30lbs injectors
-Ford racing roller timing chain
only 272rwhp. w/o nitrous. 360rwhp with nitrous with a NX 150hp wet shot.
Any suggestions on how to make it 300rwhp on motor. I am thinking a chip.
You haven't ever done a search on this topic, have you. :nonono:
Check this thread just 4 days ago;
http://forums.stangnet.com/showthread.php?t=498627
Do a search.....all your questions about the TPS for the 94/95 5.0 will be answered in 5 minutes.
With regards to your hanging idle.......remove and clean the snot of the IAB valve with TB cleaner. Replace your ECT/ACT sensor's if they are old. Their output starts to become wonky when they get old which can cause idle problems (and no, they may not set off a CEL). Make sure that the two sensor wires inside your MAF meter are clean. Check for vacuum leaks. Check for exhaust leaks. After you've done all that, unplug the battery to reset the PCM.
If everything above checks out, then you may just have to accept the fact that you're idle is not going to be great with the mods you have done. Some people have had good success using tweaker to get their idle under control with H/C/I mods.
Longtube headers and an offroad H pipe would help.
Cheers
