tps tec
  • Thread starter Thread starter notchman90
  • Start date Start date Oct 27, 2004
N
notchman90
87
long isle, ny
Oct 27, 2004
  • Oct 27, 2004
i was wondering if anyone ever heard of a tps tec, it is supposed to reduce dead spots and assure constant voltage. do they work and are they worth it?
thanks
89rdgt
103
Washington
Oct 27, 2004
  • Oct 27, 2004
I dont know never seen it so I did a google search and found it. Hmmm... I dont know I kinda stay away from things like that. I would be kinda warry about it. If your factory tps has dead spots or doesnt reach 5.00v at WOT then replace it. Its designed to not have dead spots in the sweep. I think this product may mask a potential issue with a tps.
I have not tested or tryed this product this is only a opinion. Maybe somone who tested maybe more help.
TrickStang37
292
  • Oct 27, 2004
my TPS has never read 5.0v at WOT.
J
jd351
163
Everett, WA
Oct 28, 2004
  • Oct 28, 2004
TPS voltage should be at least 4.8 volts at WOT. If not TPS is bad or out of adjustment. No dead spots should be present, and watch to make sure it does not go up to 5.0V and drop back down while opening the T/B to WOT.
I too have seen these and assume they are just some sort of "gaget" designed to fool the EEC by giving a non-linear increase to the TPS voltage.
They claim to limiting voltage to a 5.00 max. and indicate WOT earlier. Thus making the EEC believe you are at WOT earlier and putting the EEC in Open loop, not good in my opinion. Reminds me of the early days of computer engine managment systems when people would drill holes in the exhaust upstreem of the O2 sensor, believing this would fool the computer into "thinking" the engine was lean and thus sending more fuel to the engine.
May sound good in someones mind, but deosn't work in practice... will not go into the why.
Help! Fox with idle issues
  • bbarton
  • Sep 11, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 12, 2026
AeroCoupe
Electrical Defrost switch ignition?
  • Teen'93stang5.0
  • May 16, 2026
Fox 5.0 Mustang Tech Jun 3, 2026
Teen'93stang5.0
C
Electrical Fuel Gauge...Help! What did I do or Didn't Do?
  • ChickenDeluxe
  • Sep 3, 2026
Fox 5.0 Mustang Tech Sep 3, 2026
ChickenDeluxe
C
Drivetrain Tail Shaft bore odd shape
  • R82148V
  • Jun 12, 2026
Fox 5.0 Mustang Tech Jun 13, 2026
Mustang5L5
T
Inside is completely dead
  • TunaCar
  • Oct 18, 2026
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Oct 20, 2026
DadLife0724
