TPS voltage at Wide-Open-Throttle Enhancer For 94-95 Mustang 5.0
I wouldn't go there. It's a device that attempts to correct faulty TPS voltage reading at WOT (points above 70% open which is a trigger point for various functions such as A/C cutoff). If the TPS is not showing full voltage at WOT ( or the full range from idle to WOT) the sensor should be replaced. Cheap fixes are not the answer.
The spacer takes the slack out of the throttle cable so you get the butterfly valve in the throttle body open 100% (TPS voltage at 100%). Which means it's easier to hit WOT. It also brings the gas pedal up about even with the brake pedal. The only downside I can think of is that you'll likely stretch out the throttle cable over time, since the gas pedal doesn't completely hit the floor at WOT.
Before I did this mod, to get WOT I'd have to slam the pedal to the floor, and then only sometimes. After the mod, no problems.
Snake oil. TP for WOT in a typical 94-95 from the factory is 642 AD counts - where max is 1023 AD counts just about 5v. So at about 63% throttle, the PCM thinks it's at WOT anyway - don't have to matted...
