I usually hang out in classics, but I figured you 5.0 guys would probably be a better choice for this one. I have a tremec 3550 in my car, and it's been in there for 2 years (almost exactly) with no problems. Very recently I started getting a noticable vibration right around 2000 RPM in every gear. I can feel it most in the clutch pedal and the shifter. I'm pretty sure it's not the engine because I have a fluidampr and there's not much that can change in the engine balance if it was right in the first place.
I have a lakewood scattershield and when I put it all together I didn't check to make sure it was all centered like you're supposed to. I just put it together and it worked fine for 2 years. I'm afraid I might have messed up the input shaft though, if it's not really centered like it should be. I pulled the tranny and there is a little play in the input shaft. The splined part moves around just a little inside the outer tube (I can wiggle it back and forth). I didn't pay attention when I put it in, so I don't know if it always did that. Does anybody know if it's supposed to be perfectly tight in there, or if it can have a little play? And if it is messed up, how hard is it to fix? Can I just buy a new input shaft and bolt it in?
