track heat heads
  • Thread starter Thread starter 89streetbeast
  • Start date Start date Dec 26, 2006
89streetbeast
365
horton,ks
Dec 26, 2006
  • Dec 26, 2006
ok im gonna upgrade my heads and was considering the track heats. heard from others that its the same as the twisted wedge but with better springs and no heat crossover. so by that they should work with my .030 trw pistons with no ptv problems correct? i plan on getting another set of 1.7 crane stud mount rockers for it so thats taken care of. only other question is what will be needed besides the obvious gaskets, headbolts and pushrods to bolt them on?
thanks guys
bluevenom867
I will have images of molesting stuffed animals in
Dec 15, 2003
1,704
St.Petersburg,FL
Dec 26, 2006
  • Dec 26, 2006
It should work with the stock cam and 1.72's,but always check.
89streetbeast
365
horton,ks
Dec 27, 2006
  • Dec 27, 2006
might go get some clay just for safety lol. i know the valves dont hit now but they are stock valves for E7's which is small compared to the 2.02's in the trick flows lol. i'd hate to get a smaller cam cuz the stall i got kicks in around 3500 for the powerband with the cam i have now. nothing like hittin the transbrake and launch at 4g's real necksnapping for a turd motor
blkcobra50
209
  • Dec 27, 2006
You will need to measure for correct length pushrods. TFS require longer pushrods. I needed 6.75" pushrods. As far as P/V clearance, always check.
bluevenom867
Dec 15, 2003
1,704
St.Petersburg,FL
Dec 27, 2006
  • Dec 27, 2006
Ahh yes,you do have to replace thous too.Make sure you buy hardened one for use with guide plates.
And make sure you get the correct size rockers,the TFS use a 7/16" stud for the rockers.
D
Daggar
3,902
  • Dec 28, 2006
--moved to tech--
Modular2v
3,222
23
99
oklahoma
Dec 28, 2006
  • Dec 28, 2006
if you have a stock decked 302 based block and the heads have not been milled....with a 1.6 rocker , a 6.75 pushrod is required
89streetbeast
365
horton,ks
Dec 28, 2006
  • Dec 28, 2006
whats a good piston brand to go with for larger valve reliefs? i wanna stay with forged pistons. maybe something like SRP or Ross?
thanks
Modular2v
3,222
23
99
oklahoma
Dec 28, 2006
  • Dec 28, 2006
well the pistons i have are cut for both inline and twisted wedge design.....i have probe flat tops
Engine Looking for suggestions and or ideas
  • PonyGTrider
  • Aug 25, 2026
PonyGTrider
C
Dyno day! # guesses?
  • clayton seiders
  • Aug 15, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Aug 16, 2025
Scrapla347
M
Engine Unexplainable Exhaust Pop and Gurgle
  • Mrnissen122
  • Feb 14, 2026
Fox 5.0 Mustang Tech Feb 18, 2026
  • 68_Disgustang
  • Feb 22, 2026
1965 - 1973 Classic Mustangs -General/Talk- Oct 19, 2026
mattcrp1
M
Resolved Noisy Valvetrain
  • PonyGTrider
  • Jun 15, 2024
5K
Fox 5.0 Mustang Tech Jun 19, 2024
PonyGTrider
