Traction Bars and Sway Bars...
  • Thread starter Thread starter spirockp
  • Start date Start date Apr 13, 2009
spirockp
5 Year Member
Mar 26, 2004
465
12
39
NJ
Apr 13, 2009
  • Apr 13, 2009
If I am running Traction Bars (slapper bars) should I be removing the rear sway bar?
The reason for asking is that I have wheel hop and have installed a set of slapper bars and I am having trouble dialing them in. I have reduced the hop but not completely.
I still can't believe I have wheel hop with my set up.
66 Mustang Coupe
Stock 302 - about 225 hp
C4 trans - no shift kit
Limited Slip Rear (of course)
Complete suspension rebuild front and read with poly
1 inch lowering leafs - 138 lb rate
Front Shelby drop and 620 lowering front springs
Front and read upgraded sway bars
Thanks.
Peter S.
latamud
791
Tampa, FL
Apr 13, 2009
  • Apr 13, 2009
How are your motor mounts? A weak drivers side mount could cause a wheel hop feeling. A torque strap could help or a solid mount on the drivers side. We run a bolt through the two pieces on the mounts to keep the rubber from separating. I learned this trick from John at Opentracker.
this is an early 65 but the same concept applies to the late 65+
This is what happens
This is what we do
This is what it looks like when done.
spirockp
5 Year Member
Mar 26, 2004
465
12
39
NJ
Apr 13, 2009
  • Apr 13, 2009
Latamud, are you saying it could cause wheel hop or just make it feel like wheel hop? I did not have any issues until I upgraded to Limited Slip, so if your saying a bad motor mount can cause the same feeling then I should of felt it even before I installed limited slip. Correct?
latamud
791
Tampa, FL
Apr 13, 2009
  • Apr 13, 2009
It could feel like wheel hop. Its a stutter in acceleration, caused from the engine torquing over which can feel like wheel hop. I will say that this might be an issue if your motor mount decided to let go right after to installed the limited slip. To test, you can start the engine and watch to see if it torques over when you rev it. If your mounts are good then don't worry about them. I'm just thowing out the odd diagnosis that would otherwise get overlooked and is easy to test.
I didn't like the slapper bars, great for acceleration but not so much for deceleration. I swapped to under-ride traction bars and even then had some movement.
Rusty67
20+ Year Stangneter
Dec 3, 2002
3,749
37
109
LA, CA
Apr 14, 2009
  • Apr 14, 2009
First off... latamud wear some gloves man !
Anyways, I wouldn't think that a sway bar would contribute too much to wheel hop. What kind of leaf spring eye bushings and shackles did you use ? What kind of shocks do you have in the rear ?
rbohm
6,698
550
204
tucson,az
Apr 14, 2009
  • Apr 14, 2009
a bad trans mount can also cause the wheel hop sensation.
spirockp
5 Year Member
Mar 26, 2004
465
12
39
NJ
Apr 14, 2009
  • Apr 14, 2009
Eaton 1 inch lowering springs - 138 lb rate
Upgraded shackles - (forget exactly what brand)
and KYB shocks all around
Don't forget poly everything.
Rusty67
20+ Year Stangneter
Dec 3, 2002
3,749
37
109
LA, CA
Apr 14, 2009
  • Apr 14, 2009
GR2 or Gas-A-Just shocks ?
latamud
791
Tampa, FL
Apr 14, 2009
  • Apr 14, 2009
To each his own. I like getting my hands dirty. John used to get on my case about gloves. I know how to wash my hands when I'm done.
zookeeper
3,415
63
109
Rogue River, Oregon
Apr 15, 2009
#10
  • Apr 15, 2009
  • #10
Ever eat a sandwich with hands so dirty you leave fingerprints on your food? I have, and have had no ill effects yet. It completes the car building experience.
Rusty67
20+ Year Stangneter
Dec 3, 2002
3,749
37
109
LA, CA
Apr 15, 2009
#11
  • Apr 15, 2009
  • #11
Ever see the movie Basketball ? Thats what I'm thinking right now lol.
BTW, if you think the rear sway is causing issues, they aren't that hard to take off. Pull it and see how the car rides.
latamud
791
Tampa, FL
Apr 15, 2009
#12
  • Apr 15, 2009
  • #12
Wouldn't even have to pull it out, just unhook the end links or the mid bushings.
Rusty67
20+ Year Stangneter
Dec 3, 2002
3,749
37
109
LA, CA
Apr 15, 2009
#13
  • Apr 15, 2009
  • #13
Quite true, you could just disconnect the end links.
Suspension End link replacement size
  • Teen'93stang5.0
  • May 12, 2026
Fox 5.0 Mustang Tech May 20, 2026
Teen'93stang5.0
F
Sway Bar Endlinks
  • Fri Guy
  • Jun 30, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 30, 2025
Fri Guy
F
G
Front Sway bar HELP
  • Grabberblueguy77
  • May 28, 2025
2005 - 2014 S-197 Mustang -General/Talk- May 28, 2025
gkomo
Fox Another try for the European guy to get his first Fox
  • Schargedfox
  • Aug 3, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Aug 4, 2026
DadLife0724
R
  • riored97snake
  • Jun 18, 2026
  • What is it Worth?!?!?
riored97snake
R
