TRACTION PROBLEMS... Rant
  • Thread starter Thread starter Piston
  • Start date Start date Jul 7, 2004
Piston
215
Chicago Suburbs
Jul 7, 2004
  • Jul 7, 2004
I'm regretting a lot of past decisions that I made to my car now!
Alright, back when my car was lightly modified I bought some suspension mods. I bought FMC B springs which lowered and stiffened up my ride. I bought Hotchkiss control arms and had the pinion angle done. I bought Koni Yellow adjustable shocks and struts. They are set to the softest ride possible. Now with my old 302 (324.5 RWHP) car I have had some serious traction problems that got even worse with the new 331. The only difference was I went from 18inch wheels to 17inch 2003 cobra's with a 315 drag radial tire that basically went bald after 200 miles. I torched those tires. The tires don't really bite as good as I need them to since with my 3.73 gears I have no first and second gear I have to ease the throttle for traction.
Alright so the real question is: Seeing these suspension mods does anyone have any idea's on what I should buy or do to get some more of my traction back? I would at first like to avoid replacing parts I have already put on. I do realize I may have to but I'm trying to avoid it since I rebuilt everything in the engine bay once before.
MONEY PIT :damnit:
Just getting started modding your car? Heed these words:
"DO not under estimate your desire for HP! It's addictive "
TT91
1,536
Paramus, NJ
Jul 7, 2004
  • Jul 7, 2004
WELL..if your looking for weight transfer to the rear wheels for traction, your not going to be able to do it with the FMS B springs. I know alot of guys run the eibach drag launch kit and still have the lowered look that im sure you want to keep.Removing the sway bar(front) is always an option, but not a very safe one. You should be alright with the Koni yellows since they adjustable, unless you looking for serious tracking, a set a lkewood 50/50 and 90/10s could be in order. Hope i helped, good luck...im in the same boat u are.
Piston
215
Chicago Suburbs
Jul 7, 2004
  • Jul 7, 2004
What about a pan hard bar? Not sure if that's what it's called? I agree with the drag springs and the lakewood shocks/struts but is there anything else?
I have considered removing my sway bar.
TT91
1,536
Paramus, NJ
Jul 7, 2004
  • Jul 7, 2004
yea a panhard bar and torque link would probably be a really nice setup with your current mods.
Pod
71
Cambridge, UK
Jul 7, 2004
  • Jul 7, 2004
If you decide to replace the 'B' springs, let me know - I'm after some of them.
Piston
215
Chicago Suburbs
Jul 7, 2004
  • Jul 7, 2004
What brands? Any recommendations?
Piston
215
Chicago Suburbs
Jul 7, 2004
  • Jul 7, 2004
Alright I will I will know a bit more in 2 weeks what I'm going to do.
If you got AIM add my TR1FORC1AN. I actually think I might want to sell them contrary to what I just wrote up there.
TT91
1,536
Paramus, NJ
Jul 7, 2004
  • Jul 7, 2004
theres only two companies to really choose from, Maximum Motorsports and Griggs, both awesome setups.
rd
3,316
63
109
Ocean Springs MS
Jul 7, 2004
  • Jul 7, 2004
With that size DR's, and a decent burnout, you should be able to hook. I would try removing the front swaybar, (track only), trying different tire pressures, etc. The only part change that I see needed might be to install some lift bars, like Megabites or Southsides and maybe and airbag.
Mine hooks nicely with all stock stuff in the rear, 1982 rubber bushings, boxed stock lca's, old Lakewood traction bars, unknown shocks, etc. Adding the rear swaybar back helped. 275-50-15 DRs stick like glue, after proper warmup.
DJTR
228
OTTAWA, Ontario, Canada
Jul 7, 2004
#10
  • Jul 7, 2004
  • #10
Hey now don't forget Kenny Brown!!!!!
Piston
215
Chicago Suburbs
Jul 7, 2004
#11
  • Jul 7, 2004
  • #11
Well I did notice that running 25lbs of pressure and a burn out I got traction but I had to take it easy out of the hole and I couldn't completely floor it. So I know there is hope for these tires but suspension is my next agenda because I want to come outta the whole at 5k. After I do beef up my rear end. What's the lowest recommended tire pressure on those drag radials?
TIMMY2734
1,330
Queens, NY
Jul 7, 2004
#12
  • Jul 7, 2004
  • #12
First thing id do is ditch the shocks and struts and go with something more drag oriented. Something liek the lakewoods or Strang adjustables fair very well. Do yourself a favor and get some real tires. Put a set of et streets or drags on a 15inch rim or even your stockers.
Legendary
1,925
City of Angels
Jul 7, 2004
#13
  • Jul 7, 2004
  • #13
MM has my vote. But my car is more setup for autocross.
http://www.cardomain.com/memberpage/582401/4
R
rks'92/5.0
#14
  • Jul 7, 2004
  • #14
adj. rear sway bar:http://www.maximummotorsports.com/rsb.asp or better yet just call maximum motorsports. 805-544-8748
Piston
215
Chicago Suburbs
Jul 8, 2004
#15
  • Jul 8, 2004
  • #15
Thanks guys... I will be buying some stuff from MM. I'm going to inquire about a group discount if anyone is interested let me know.
T
Digital Tuning Hello OBD2 problem
  • TNmach1
  • Sep 18, 2026
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Sep 18, 2026
TNmach1
T
Electrical Headlight harness trouble
  • 1985fox
  • Apr 14, 2026
Fox 5.0 Mustang Tech Apr 17, 2026
AeroCoupe
D
Will 2023 (Non-Handling Pack) Mach 1 Wheels Fit A 2013 Mustang GT OK?
  • dmw_4814
  • Oct 27, 2026
  • 2010 - 2014 Specific Tech
2010 - 2014 Specific Tech Oct 27, 2026
dmw_4814
D
H
Forced Induction On3 Turbo Kit- Parts list NEEDED - 302 Stock Motor
  • Hirothecool1
  • Feb 27, 2026
2K
Fox 5.0 Mustang Tech Mar 7, 2026
slow84lx
Surging/stalling! problem or tune?
  • djj62478
  • Oct 4, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Oct 14, 2026
KRUISR
