- Mar 30, 2005
- 4,749
- 95
- 134
How do I do it? Is it difficult? Are special tools required?
What would the Ford dealer charge for this?
hognutz said:those instructions are for a different trak lok than is in my car.
there is no speed sensing ring on my carrier. also there is no need to remove the case bearings. Iknow it came apart with the ring gear on. I did not put it back together to see if you have to have the ring gear off to get the s-spring back in.
Well, I have 20k on the 80W-90 do you think it still is possible that it is ok? I do not get "one wheel peel"...svttech76 said:kilgore you might not need it rebuilt. just drain and fill your diff and see if your traction-lok works.
Kilgore Trout said:Well, I have 20k on the 80W-90 do you think it still is possible that it is ok? I do not get "one wheel peel"...
svttech76 said:no thats the same trac lok that in your car. but thats the instructions for the NON pre shimed clutch packs. the kit most of us buy is the pre shimed ones. the pre shimed ones come with instructions.
the reason the bearings have to come off is too use the special tool for measuring the clutch packs. and yes you do have a tone ring like that. it's sandwiched behind the ring gear and is removable.
you can do the PRE SHIMED ones with the ring gear and bearings and stuff in place. in fact i do them in the car, i don't even remove the carrier when doing the pre shimed kits.
the non preshimed is better because you can set the action of the traction lok, in fact some people are removing one plate and adding a extra clutch disc
hognutz said:my gears will not slide through top hole in the diff. I can post pics if you want. I have it sitting right out in my garage.
there is not tone ring there either. I just pulled the ring gear. there is the carrier and the ring gear that is it. that is the same way my 31 spline I just installed was as well.
my abs tone rings are on my axles.
hognutz said:this is the pic I am refering to. I can't do this with my carrier. the clutch packs have to go into the center then up into the carrier.
it might just me me confusing what they are showing.
