Hey everyone I am going to be installing a tranny cooler this weekend and I was wondering if anyone had any pictures of their install or instructions on what they did. Thanks.
nic01scgt said:Hey everyone I am going to be installing a tranny cooler this weekend and I was wondering if anyone had any pictures of their install or instructions on what they did. Thanks.
Since you started it, I'll throw my thoughts in. No flaming. Just my thoughts...sgarlic said:There is TONS of debate on whether or not you should keep the radiator in the chain or not. Some say no, because the cooler you're putting in is better. I say yes, for 2 reasons:
1) The heat of the radiator helps bring the tranny fluid up to operating temperature faster in cold climates.
2) 2 coolers are better than one. I don't care how little the radiator tranny cooler does. It cools it some. And that's all the less the auxillary cooler has to do.
propellerhead said:Since you started it, I'll throw my thoughts in. No flaming. Just my thoughts...
1) In cold climates where you need to heat up the transmission fluid, the thermostat in your engine will be closed (or almost closed). There will be none or very little radiator fluid flowing. The radiator will be getting a blast of artic wind and will be cold. It won't be hot enough to provide any real warming to the transmission fluid.
2) The Hayden cooler I put in is more than adequate just by itself. My transmission fluid now stays between 135 and 150 under normal driving. I locked out OD and stayed at 75 on the highway for 3-4 minutes in the Texas heat and it went up to 165. Before the Hayden cooler, the factory cooling would have the temps between 185 and 210. I'm actually thinking it's too much cooling.
propellerhead said:I've been tempted to hook the stock cooler in series and include a temperature sender in three places. Then wire them all to a switch that goes to the gauge. Like transmission -> sensor A -> stock cooler -> sensor B -> aftermarket cooler -> sensor C. Then I can switch between the three sensors and see what the temps are in different places. Then I could move the aftermarket cooler to be on the supply line, then log the temps again.
My car = rolling laboratory. Hehehehe..
