tranny fill
  • Thread starter Thread starter 87gtfoxbody
  • Start date Start date Oct 5, 2007
87gtfoxbody
cranston R.I.
Oct 5, 2007
  • Oct 5, 2007
i got a 87 gt foxbody quick question can i fill my tranny from like the shifter box or w.e.?????????
BlownFiveLiter
have car, will race....wait, it doesn't run
18
108
Chicagoland
Oct 5, 2007
  • Oct 5, 2007
T5? Pull the fill plug out, put a pan under the trans, and climb inside and remove the shifter. It should take roughly 2.8 quarts, and you'll know it's full when some fluid comes out the fill hole in the side and starts running into the pan. Pop the plug back in, pop the shifter back on, and go for a drive!
jhonda
125
Huntersville NC
Oct 6, 2007
  • Oct 6, 2007
If its the T5. ON mine I got some 1/2 plastic tubing and a small funnel. Snake the tubing down the fire wall then get under the car and put in in the fill hole, then fill
Shakerhood
20+ Year Stangneter
Oct 28, 2004
3,361
211
114
Ohio
Oct 6, 2007
  • Oct 6, 2007
X2!
grey5.0beast
Cookies should never be DUNKED!!!
Aug 3, 2004
atl ga
Oct 7, 2007
  • Oct 7, 2007
I found a better idea. I opened the shifter area but didn't unbolt the shifter, it was a bitch and I would have to reseal the shifter and ****. Instead I just took off the little rubber boot and put the funnel down right there and put about 1.5 feet of 3/8 inch tube into the fill hole. Worked great and was easy to do, didn't even have to jack up the car!
85_SS_302_Coupe
6,945
1,598
223
Northern KY
Oct 7, 2007
  • Oct 7, 2007
I hate to be the A-hole but this was just covered about 2 weeks ago
http://forums.stangnet.com/showthread.php?t=720059&highlight=trany+fill
The search button will get you the help you need, often much quicker than waiting for a reply
Shakerhood
20+ Year Stangneter
Oct 28, 2004
3,361
211
114
Ohio
Oct 8, 2007
  • Oct 8, 2007
You still have to crawl under and remove the Drain and Fill Plugs...
87gtfoxbody
cranston R.I.
Oct 8, 2007
  • Oct 8, 2007
and i can use ne auto tranny fluid 4 that or do i have to use like royal purple or w.e.
J
Foxbody trans swap
  • jimendo20
  • May 30, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 11, 2026
KRUISR
Resolved Wiring electric fan
  • cbac89
  • Aug 29, 2026
cbac89
Help! Fox with idle issues
  • bbarton
  • Sep 11, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 12, 2026
AeroCoupe
Sound deadener install
  • limp
  • Jun 15, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 17, 2026
limp
New guy from Texas
  • sreyBnoraA
  • Jan 11, 2026
  • The Welcome Wagon
The Welcome Wagon Jan 11, 2026
AeroCoupe
