tranny grinding
  • Thread starter Thread starter blue87lx
  • Start date Start date Oct 3, 2005
blue87lx
175
  • Oct 3, 2005
when i shift my tranny normal everything is smooth but when i slam it into gear it will grind. clutch is still good its a motorsports. it will even do it if i push the clutch all the way down takign my time then slammin it into gear then letting the ch out like a 3 step process it will still do it. maybe need to change fluid?
jackchan
507
Mobile Alabama
Oct 3, 2005
  • Oct 3, 2005
time for a rebuild (if clutch is good). Syncronizers are shot and or shift forks are stretched a bit.
good luck
Jack
Hanlon Motorsports has a good rebuild kit and a video and manual if needed!
sunil6784
620
Boston, MA
Oct 3, 2005
  • Oct 3, 2005
Yup, welcome to my world. my 5th gear synchro is shot, and it does exactly the same thing. I changed the fluid, and it helped a little for a while, but it just masks the real problem-the synchros.
Search on here- jrichker has a few posts with the T-5 service manual and the video from Hanlon motorsports that shows how to rebuild a T-5, very useful
As a matter of fact, that is my winter project as well.
slow93
406
  • Oct 3, 2005
i got the same thing.that damn reverse grind gets on my last nerve
dkins419
187
Michigan
Oct 3, 2005
  • Oct 3, 2005
Are you putting it into 5th gear or 4th before you put it into reverse? Otherwise it will almost always grind since 5th gear does not have a synchro.
gt40_2003wes
I did sound a wee bit gay there.
Aug 14, 2005
461
ky
Oct 3, 2005
  • Oct 3, 2005
i had the same prob with reverse then started goin from 5th to reverse works perfect everytime now.
90mustangGT
I felt sorry for girls because
2,773
17
89
Dallas, GA
Oct 3, 2005
  • Oct 3, 2005
Streached clutch cable and/or worn plastic quadrant. Unless recently replaced, I am almost sure this is your problem.
shifterpilot5.0
49
  • Oct 3, 2005
You might try some synthetic trans oil, like mobil or redline. It helped my old car alot.
slow93
406
  • Oct 3, 2005
ahhhaaaa. i didnt know that thanks for the info.
T
Drivetrain TREMEC TKX 1–2 Grinding Issue at ~4,000 Miles + Poor Warranty/Customer Service Experience
  • Ttopfoxguy
  • Oct 10, 2026
Fox 5.0 Mustang Tech Oct 15, 2026
JMG9350
J
Drivetrain Downshifting from 3rd to 2nd issue
  • Scott_S
  • Apr 23, 2026
Fox 5.0 Mustang Tech Oct 12, 2026
limp
00 4.6L V8 new clutch won’t go into gear when on?
  • Timboslice
  • Aug 15, 2026
  • The Welcome Wagon
The Welcome Wagon Aug 21, 2026
M
85 Capri 5.0 transmission rattle
  • Mamaclean
  • May 2, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- May 17, 2026
Mamaclean
M
N
Vibration after new clutch
  • nipple_looker
  • Sep 20, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 26, 2026
fasterthangas
F
