tranny mount whoas
dirty slut
59
So I go to install the tranny mount today but the new mount would not line up. I got a Urethane mount from 50resto. They said they would return the mount and Im think of goin w/ the Energy Suspension mount.
Before I do all of this I want to make sure i wasnt doing anything wrong. I took the old mount out, when I tried to put the new mount in the bolts kept trying to go in croocked, I jacked the tranny up and down a little bit but it still wouldnt go in right, You dont have to remove the H-pipe do you? Im sure it would be a little easier to get to the bolts but its not necessary is it? Am I supposed to remove the crossmember?
check your new mount against your old mount if their the same, then you might have to rethink your method, but if their different then send it back and get the e-susp, one. good luck
