tranny problem
bakes5_0
162
adrian,mi
need some help please last night i felt a vibration in my lower gears more than most but i felt a vibration on my shifter and when drivin slow or at idle i can hear somthin in almost like a tick????
and when i got the car on the lift there was tranny fluid sprayed underneath the underbody not sure where it came from cause the car has no leaks or has had no leaks.... what is goin on .....
the car does have warranty still but not sure if my add on will void that is there any way around that type of a problem as in gettin my warranty voided besides the obvious pulllin them off
thanks any info would be great
Where is the leak? The tranny tail shaft seal could be leaking. Did you check the tranny fluid level? If full, you may have a p/s fluid leak. Check the p/s fluid level.
It depends on the dealer. They could void warranty (see info in owners manual). I'd take the mods off if I didn't know the dealer.
Vibration: It is more likely a tire(s), wheel, or driveshaft out of balance. Is the throw-out bearing in good shape?
