The problem started a few weeks ago. It seemed like when i would come to a stop at a light, and i would sit for a minute or two, it would take about 5 seconds before it would let me in first gear. It would only happen maybe about 1-2 times a day. It feels like first gear lock, like when you try to put it in first going above 5 mph. Now that i have played around with it for a little bit when it happens, i tryed putting it in second gear just to go, but the same thing happened with second. When it lets me into first gear, it is very very notchy, not smooth like it should. I tried to find a way around it, and what i found is that if i put it into first when i am going about 1-2 mph, not from a dead stop, it goes in alot easier. Today, it seemed like it would not let me in gear maybe once out of every three dead stops. I have a steeda tri-ax, and i don't know if that would be causing it. Any ideas? I don't really want to take it to ford because i have a blower and i know they would give me **** for it. Also, i know that the 3650 is prone to having problems.
Get a firewall adjuster, they are cheap and easy to put in and lets you adjust where the clutch grabs.
