Tranny question
jonbacon
125
When it hits high gear it just revs.. drives fine in 1st,2nd, when it actually goes into high gear it loses power and just revs.. but I can drive it fine in 2nd...is this just a module/sensor or is my trans shot.. has factory auto in it.. replaced the filter and fluid in it. just wonderign if its a module,. if its shot im just going to order a new one..but wasnt sure if there is a module or sensor for high gear or for it to change into high correctly..
help me out so i dotn sound to stupid.. its automatic. has 1-2 and then the d .. so not fully sure.. I know there are several dif makes for it,. its nothing fancy. 92 gt, i know that when I went to get the new filter from advance, it was the wrong one, so I took the filter in with me. Finally found same part. it came out of 93 lx.. or trans for lxx accordign to computer
pretty common with the AOD; years ago I had 2 AOD's go out on me in the same fashion within a few months apart
I'd check how much it would be to rebuild and throw a shift kit in there while your at it.
