Tranny Question.
Neuron
5 Year Member
Nov 6, 2016
859
192
93
Trying to find the weight of the automatic and stick setup, all components related to each tranny style included. Auto.: Tranny, flex plate, torque converter, ATF etc. Stick: Tranny, flywheel, clutch and pressure plate, TOB, fluid etc.
That kind of depends on which two transmissions you are trying to compare.... Also changes depending on what flywheel as they don't all weigh the same. Generally speaking the auto alone (including fluid) is still heavier even after the flywheel/clutch is factored in but not ALWAYS. What transmission are you looking at?
