  • 1994 - 1995 Specific Tech
Tranny/rear whining and grinding...help!
  • Thread starter Thread starter stprorolla49
  • Start date Start date May 31, 2008
stprorolla49
1,455
15
39
Fairfield, CT/North Jersey
May 31, 2008
  • May 31, 2008
So I left school this morning in Georgia to bring my buddy home in Maryland, then head home tomorrow to NJ. I get about 200 miles or so, and after that time I noticed a slight whining coming from under the car on deceleration...not necessarily on the brakes, just coasting even. As I got farther it got worse, but the car was driving just fine. So I get to Virginia about 40 miles from my buddy's house, and I am coasting down a hill and not only is it whining, but theres a slight grinding/clanking sound coming from under the car...what I thought was the tranny...but wait it gets better. So I pull into a gas station, call AAA and have it towed the remaining 25 miles to my buddy's house. As we are taking it off the flatbed, there is a puddle of rear end fluid on the flatbed and it's clearly leaking from the differential. At this point I don't know what the problem is! I thought it was CLEARLY from the tranny cause I could feel it in the shifter, but I guess I was wrong. I stopped before it got too bad, and had it towed and my dad is coming down to Maryland with the trailer tomorrow. What could this be? At first I thought it would be either the clutch cable going, or the throwout bearing, but I replaced the throwout bearing, new clutch, and rebuilt transmission 2 years ago, and maybe only 8k miles it! Help me please!
94-302-vert
1,947
NE CT
May 31, 2008
  • May 31, 2008
If i had to guess I would say the pinion bearings / seal...
carb95
spfld MA
Jun 1, 2008
  • Jun 1, 2008
i agree with vert and if it was making a grinding noise i would also check the pinion nut and spider gears good luck
Venom351R
4,548
41
98
MAINE
Jun 1, 2008
  • Jun 1, 2008
Time for a rear end re build
stprorolla49
1,455
15
39
Jun 1, 2008
  • Jun 1, 2008
Thanks guys. I called the guy that has done many race transmissions for my dad and did my rear end rebuild/gear install, and after I told him the symptoms he said it was a classic case of the crush collar on the pinion gear going bad. This seemed weird to him considering he just did the job on my car about 4k miles ago, and this should have lasted WAY longer than that. Were gonna take the car to him next week and he said he's gonna make good on his work, because there is no reason it should have given out after such a short time.
95BlueStallion
My assy trans to myself
5,126
3,091
214
Cedar Rapids, Iowa
Jun 1, 2008
  • Jun 1, 2008
Glad to hear he is a stand up guy and backs his work. Im having more and more trouble finding those kind of people. Hope it all goes over smoothly for ya.
Bosko5.0
1,067
longwood, FL
Jun 3, 2008
  • Jun 3, 2008
I doubt the crush collar failed. The pinion seal probaly started leaking lost to much fluid and the bearings started to wear faster then normal due to lack of fluid. bearings wear = more movement = grinding
but I may be wrong I think its time for me to :Zip2:
stprorolla49
1,455
15
39
Jun 4, 2008
  • Jun 4, 2008
Yea, this makes more sense because it got worse as the drive went on. I probably lost all the fluid by the time it started grinding.
Engine Stalls when downshifting/coasting
  • Scott_S
  • Nov 5, 2025
Fox 5.0 Mustang Tech Nov 6, 2025
Mustang5L5
Drivetrain Rear end clunk
  • seanmahoney
  • Oct 13, 2025
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Oct 13, 2025
nickyb
J
2004 Mustang 3.8L V6 vibrations above 65 MPH and differential leaks
  • joeybuddy96
  • Mar 16, 2026
  • SN95 V6 Mustang Tech
SN95 V6 Mustang Tech Jul 14, 2026
joeybuddy96
J
K
TKX Transmission Shifting Problem
  • KWC156
  • Jun 23, 2025
  • Other Auto Tech
3K
Other Auto Tech Jun 13, 2026
427nostang
Progress Thread The Mach Returns - Update/build thread
  • squeak93
  • Feb 20, 2026
1996 - 2004 SN95 Mustang -General/Talk- Jun 1, 2026
squeak93
