Tranny Woes
  • Thread starter Thread starter Deleted member 87397
  • Start date Start date
D
Okay so I got my car back from the tranny shop about a month ago and since then I've really only been going on short trips since it's not registered at the moment. It's been running great without trouble. So this past weekend I got the car whipped into shape and was doing some highway shakedown runs when I had to go out. So I'm cruising down the highway at about 80 when all of a sudden I look in my rearview and I see all this smoke coming out the back and I smell burning fluid and friction material. I think the problem is that I have a kevlar OD band and the A+ servo I put in is not putting enough pressure on it. I checked my fluid the next day and it's pretty much burned and there were bits of my OD band on the dipstick. I guess I'll change out the band for a regular one and clean out the tranny, but I guess my question is where did all the fluid come from when I was rolling down the highway. Was it some kind of purge valve or something or could I have blown a seal?
Sure it was pieces of the OD band? A kevlar band will grind up the drum before it comes apart, especially with the A+ servo holding it. Did it have a shift kit to boost the pressure? I've kevlar band'ed with an A+ servo for 3K miles and the fluid looks mint.
Your best bet to find the leak is basically to look underneath it and trace the flow back to it's starting point....HOWEVER....did you lubricate the front main seal with tranny fluid first? That would cause a burn through rubber on metal then a massive fluid leak splashing all over the place and then the exhaust.
The tranny fluid could have simply picked up the crap/old fluid inside the torque converter to get the burnt up look.
I'm afraid to ask but is the TV cable hooked up? If not that would explain everything.
well the material I saw was gray and my clutches are alto reds so I don't know if it could be clutch material or not. The tranny was redone with a new converter and everything. It has and Art Carr manual/auto valve body and I shift it manual most of the time. The TV cable is hooked up and adjusted. I guess I'll just drop the pan this weekend and see if I can tell what's going on.
Ok, chances are it was old leftover factory friction material.....somewhere (converter? cooler?) that colored up your new fluid.
Did it feel funny like it was neutralling or revving up or the band slipping?
The higher rpms boost pressure from the front pump. It is also possible the rear main seal wasnt lubricated and burnt out. The driveshaft would sling the ATF onto the catalytic converters and cause a lovely smokescreen.
There is a breather cap atop the rear housing of an AOD but I would be shocked if fluid came gushing out the top.
Best bet..... wipe all the fluid off and idle till the ATF burns off the exhaust. Clean it up again. Put the rear end on jackstands, stand the car, put it in drive and get up to OD/80 mph in the air. Have a friend look to see where the splashing is coming from front/rear then stop the car. The atf will paint the culprit for you. I suspect front or rear main AOD seal since it is common to forget to prelube them. You could also be leaking from the cooler pressure/return lines where they meet the tranny in the side.
Yeah after I had all the smoke coming out and got off the highway it felt like it was neutraling when I would go up through the gears. Thanks for the input. I'll throw it up on stands this weekend and check it out.
Well, if it was from a stop pedal pressed:
neeeeeeeuuuutral KICK pull like normal
then you're insanely low on fluid. Fill before you drive again or bad things will happen.
If it's instant response but slippity slippity sorta free revving but still pushing the car, you've got burned internals....clutches and bands. Too low a pressure will cause the bands to slip. Low fluid will also cause this to happen if you get so low you uncover the pickup.
