tranny???
  • Thread starter Thread starter Hitman8728
  • Start date Start date Feb 12, 2004
H
Hitman8728
15
  • Feb 12, 2004
hey guys i have a 65 mustnag right now it has the stock tranny in it.. well i hurd that the cruse o matic is not so g8 even to build up.. i also hurd the 67 was better. my question is, i have a 67 auto from a v6 is that one better to build up. thank every one that helps me out.
SuperDave
Early-Model Mentor
6,361
Tacoma, WA USA
Feb 12, 2004
  • Feb 12, 2004
You most likely have a C-4. "Cruiseomatic" is just name not a type. The C-4 is a fine transmission for a build up. (You "hurd" wrong.)
H
Hitman8728
15
  • Feb 12, 2004
would this be an ok drag race tranny
SuperDave
Early-Model Mentor
6,361
Tacoma, WA USA
Feb 12, 2004
  • Feb 12, 2004
Certainly. It is very common.
H
Hitman8728
15
  • Feb 12, 2004
thx a lot superdave... do u think and aod would be a better choice or just spend the money on my cruseomatic c-4 build that up a bit
dolfan87
1,242
Lake Havasu, AZ
Feb 12, 2004
  • Feb 12, 2004
Hitman, the AOD is a great transmission. It's as strong or stronger than the C-4, plus it has an overdrive.
However, if you're just looking to drive around town, and drag race once in awhile, the C-4 will be cheaper (since you already have it) and also hold up fine.
87
G
GaPonyFarm
663
Columbus, GA
Feb 12, 2004
  • Feb 12, 2004
The '67 has a better valve body for buildups... You can make a C4 just as tough as you want, and it makes a fine racing transmission. I personally, wouldn't trust an AOD for hard racing, but thats just my preference. I wanted alot of strength AND overdrive, so I built up my C4 and added a Gear Vendors under/overdrive unit. Its definitely all I need it to be.
H
Hitman8728
15
  • Feb 12, 2004
is the v6 trann the same as the v8 one?
D
D.Hearne
11,730
south louisiana
Feb 12, 2004
  • Feb 12, 2004
There were no V6's in the early Stangs. You're mistaking the straight six for a V6. Some of the straight 6 C4's will work with small blocks ( 289-302's)
12sec67
1,301
San Diego, Ca
Feb 12, 2004
#10
  • Feb 12, 2004
  • #10
if you plan to drag race on a budget stick with the C4. you can build a really strong C4 for cheap, or buy a fully built C4 from GER for $599. The AOD needs to be built before it can handle the shifting you need to drag race. Doing the 1-D-1 shuffle that you'll be doing doesn't help the longevity of an AOD.
good luck with whatever you decide
Rich
Frankies65
275
Bucks County PA
Feb 13, 2004
#11
  • Feb 13, 2004
  • #11
The only downside of a 65-66 C4 is the goofy green dot shift pattern and the double shift L-D2-L to go from 1st to 2md while manually shifting. The 67-68 valve body is a bolt-in that eliminates this problem. This is really only an issue if you want to put in a manual shifter and a shift kit. Otherwise not much difference between the years. There are a lot of performance parts available for the C4's. Just change the valve body.
Frank
347 with Vortech V2 and Holley quick fuel, AFR Renegades a tremec tko 600 advice for newbie pls
  • Schargedfox
  • Jul 20, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Aug 3, 2026
Schargedfox
Drivetrain Wilwood Clutch and Brake Pedal Combo Installation - Help
  • 427stang
  • Jul 8, 2026
Fox 5.0 Mustang Tech Jul 8, 2026
427stang
C
Help with manual conversion
  • CPH89LX
  • Aug 23, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Aug 27, 2026
2000xp8
Progress Thread Progress Thread- From6to8's 95 GT/Saleen Supercharged 331 install
  • from6to8
  • Mar 22, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Monday at 5:48 PM
from6to8
9
Sn95 3.8l coolant leak
  • 98joyboy
  • Dec 4, 2025
1996 - 2004 SN95 Mustang -General/Talk- Dec 4, 2025
98joyboy
9
