  • SN95 V6 Mustang Tech
Tranny?
  • Thread starter Thread starter Stang_232
  • Start date Start date Mar 13, 2007
Stang_232
23
Dewitt Michigan ugh!
Mar 13, 2007
  • Mar 13, 2007
I have a 2001 V6 with Auto and 105k miles. At idle it lopes bad between 700rpm and 1200rpm when its in drive/gear. At highway speeds or cruising feels like its shifting in and out of gear Lansing Transmission told me i have a ignition prob but i installed a new coil pack, plugs and wires, and a new fuel filter I appreciate any help TY.
stanging97
14
  • Mar 21, 2007
sounds to me like your forward clutches are going bad. do you ever "power brake" it or do "brake Stands"?
2muchtime
890
MA.
Mar 22, 2007
  • Mar 22, 2007
i dont think its your tranny. you need to scan the computer for codes..
if you were having trans problems there will be a fault code stored..
the engine is probably just bucking making it feel like a trans problem.
Stang_232
23
Mar 24, 2007
  • Mar 24, 2007
The only codes i have r 0420 0430 for the cats but those r off am i not getting enough back pressure it just started doing it recently and its been 6 months since ive had that cats taken off.
Stang_232
23
Mar 29, 2007
  • Mar 29, 2007
But i've never Braked tourqued it though now with the warmer weather its not really doing it.
CobraRed_96_GT
1,421
UCSD/La Jolla
Apr 5, 2007
  • Apr 5, 2007
sounds like the clutch plate in the torque converter is slipping/mush, a common prob for 4R70W's around 35-45mph
Stang_232
23
Apr 6, 2007
  • Apr 6, 2007
Is that a bitch to fix im pretty mechanically inclined worked at a dealership and Auto classes for two years but didnt dick w/ trannys to much Automatics anyway?
D
DarrinB
40
Carmel. IN
Apr 9, 2007
  • Apr 9, 2007
Sorry guys, it sounds like none of the above. The computer controls idle and RPM. If it was a slipping transmission then this wouldn't happen unloaded at idle like that. It is impossible for it to be the torque converter clutch because the torque converter is not applied at idle.
What I would do is get the thing hooked up to something that you can watch what the car is doing like a Ford NGS or an Xcal 2 or similar. You can see from that data what the computer is doing and the place its making its changes will show you what you need to look at.
Darrin
p0740
  • Roont
  • Oct 19, 2025
2005 - 2014 S-197 Mustang -General/Talk- Oct 19, 2025
horse sence
P
2002 T5 transmission vibration issue
  • puffoo
  • Feb 22, 2026
SN95 V6 Mustang Tech Feb 22, 2026
puffoo
P
idles perfect then jolts and cuts out when put into Reverse or Drive.
  • shanesstangs
  • Mar 12, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Apr 27, 2026
General karthief
'04 V6 running rich excessively on both banks
  • 04DSGVert
  • Oct 26, 2025
SN95 V6 Mustang Tech Oct 27, 2025
04DSGVert
A
Car is running bad
  • Anthony3511
  • Apr 30, 2025
SN95 V6 Mustang Tech Apr 30, 2025
89ripper
