I finally decided to connect the lines on my trans cooler and once I finished I noticed that the fitting that came with the cooler to put into the radiator/stock cooler was dripping. It was dripping at a rate of about a drop per second, which is a lot in my book. Is it safe to use teflon tape on the fitting? Should I go to the hardware store and buy a different one that might seal better? Any other suggestions?
*Heres a pic of a similar fitting. The threaded end goes into the radiator - that's where it is leaking from.
