  • SN95 4.6L Mustang Tech
trans fluid question
  • Thread starter Thread starter 19MustangGT96
  • Start date Start date Aug 21, 2006
19MustangGT96
  • Aug 21, 2006
how much ATF does a 4R70w Trans hold?
K
Kilgore Trout
Fried or Broiled ?
4,749
95
134
Aug 21, 2006
  • Aug 21, 2006
The answer is in your owner's manual.
19MustangGT96
  • Aug 21, 2006
Thanks smart a$$. i am at work and my car is at home and io just got it together and i was going to go buy atf after work on my way home. i figured it was not a complicated question. but hey thanks for the input i would never guess it was in the manual NOT
K
Kilgore Trout
Fried or Broiled ?
4,749
95
134
Aug 21, 2006
  • Aug 21, 2006
It takes 12.8 quarts if you drain the tranny and the TC.
stangGT97
1,299
Boston area, MA
Aug 21, 2006
  • Aug 21, 2006
Mercon ATF, 12.8qts or 12.0L (according so my 1997GT manual)
19MustangGT96
  • Aug 21, 2006
Thanks for your replys...i appreciate it
K
Kilgore Trout
Fried or Broiled ?
4,749
95
134
Aug 21, 2006
  • Aug 21, 2006
If you only drain the pan you will need about 6-7 quarts. Also, if this has never been done before you will find a plug in the pan. This is just a dust cap from the assembly line and can be discarded. Be sure and change the trans fluid filter also.
Proper Transmission fluid for a 84nwc t5
  • Sask84gt
  • Mar 7, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Mar 10, 2026
Sask84gt
M
85 Capri 5.0 transmission rattle
  • Mamaclean
  • May 2, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- May 17, 2026
Mamaclean
M
C
C4 trans help needed
  • CPH89LX
  • Apr 26, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Apr 28, 2026
CPH89LX
C
Brake Fluid shelf life?
  • Bullitt347
  • Sep 28, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 29, 2026
nickyb
D
Brand New C6 Transmission Pouring fluid
  • Danielperry2003
  • Jun 17, 2025
  • Other Auto Tech
Other Auto Tech Jun 17, 2025
General karthief
