Trans noise.. not the normal issues...
  • Thread starter Thread starter MaxTheHooker
  • Start date Start date Jul 2, 2008
M
MaxTheHooker
36
  • Jul 2, 2008
So, i just had a spec stage one with a spec aluminum flywheel, new friction surface and bolt assembly, and new 50 oz weight put on the flywheel.
the people at the transmission shop are retarded and have been working on my car for a while now.
when they got the car started, there was this terrible "clanking" noise coming from the flywheel. like, it happened maybe twice a second just a loud clicking-like sound.
however, when he bent the plate back (i don't know what it's called, it's the one that sits between the flywheel and the block, and bolts to the tranny... the flex plate, perhaps?), when he bent it back, the sound would stop..... so at first, we thought hte bolts connected the new friction plate to the flywheel were a little long. after grinding them down a bit, we noticed that the knock hadn't gone away.
tomorrow i'm staying after with one of the guys, after shop time, in order to find out what's wrong with this.
also, when i press down on the clutch pedal, the noise also goes away.
my thoughts are that the pressure plate is grinding against the bell housing, and that i need to drop the trans again and i will find the grinded up bell housing... i think i'm just gonna grind it out more until everything clears and call it a day...
HOWEVER, i was wondering what you guys thought? anyone had this problem? my buddy said he had it with his king cobra clutch and that when his uncle did his clutch, he did the exact same thing (shaved away some of the bell housing) and everything worked out fine.
any suggestions? (i know it's hard to diagnose right off the bat, and i'll try to get a video up of it tomorrow some time.)
M
MaxTheHooker
36
  • Jul 2, 2008
anyone?
SMOKEDYA
20+ Year Stangneter
Jul 13, 2003
3,637
Tucson AZ
Jul 2, 2008
  • Jul 2, 2008
i've never heard anything like this,the plate is a dust sheild a flex plate is for an auto tranny. but sounds as if some how the presure plate is hitting or they didnt torque something right? couriousto know whats up tho? peace
john
T
Drivetrain TREMEC TKX 1–2 Grinding Issue at ~4,000 Miles + Poor Warranty/Customer Service Experience
  • Ttopfoxguy
  • Oct 10, 2026
Fox 5.0 Mustang Tech Oct 15, 2026
JMG9350
J
N
Vibration after new clutch
  • nipple_looker
  • Sep 20, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 26, 2026
fasterthangas
F
M
85 Capri 5.0 transmission rattle
  • Mamaclean
  • May 2, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- May 17, 2026
Mamaclean
M
P
2002 T5 transmission vibration issue
  • puffoo
  • Feb 22, 2026
  • SN95 V6 Mustang Tech
SN95 V6 Mustang Tech Feb 22, 2026
puffoo
P
C
Drivetrain T-5 transmission issue
  • Ch3No2
  • Jul 11, 2025
Fox 5.0 Mustang Tech Jul 18, 2025
2000xp8
