Trans noise??
Johnson505
66
After installing my MGW shifter I noticed more tranmission noise in the car. It kind of sounds like it did when I had the trim around the shifter off with the stock shifter. I was wanting to know if this is normal or if my trans or shifter is not right. It is kind of a growl sound. It is not consistant. Sometimes it is louder than others. What do you guys think?
The aftermarket shifters don't have the sound deadening material that the stockers do. There are the rubber grommets between the shifter handle and the shifter itself and the gaskets between the ****er and tranny on stock pieces. You can just fashion a rubber gasket to fit in between the shifter and the tranny if the noise is bothersome.
