trans stuck in nuetral
out last night and shifted into 2nd gear from a light and the car just stayed in nuetral and just revved when i pushed the gas pedal. i have pressure on the clutch pedal so the clutch is still there. checked the if the the throwout bearing was working right and it seems well. i pulled the shifter out thinking i pulled it out of socket (had that problem before) that was not the problem. i can put it in gear and crank the car and the car just idles and wont go. any thoughts on what could be the culprit. built t56 thanks guys
