  • SN95 4.6L Mustang Tech
transmission conversion
  • Thread starter Thread starter RedBullitt
  • Start date Start date Dec 2, 2004
RedBullitt
462
Morgantown WV
Dec 2, 2004
  • Dec 2, 2004
alright, im diving in over christmas break, god be with me lol. i think i have everything, can someone throw a good parts list at me for converting an 01 gt auto to a tremec 3650? just to make sure im not forgetting anything. ; )
also, i need a few key bolts and stuff like that, little bits and pieces, does anyone know of a good site for these kinds of things? also, any info on the ecu swap and necessary wiring would be awesome.
thanks alot
N
narongc73
146
  • Dec 2, 2004
thanks alot
Only place I can think of is the junk yard, unless you want to try stangparts.com. As for ECU just get a manual one and get the PATS redone at the dealership else you won't be able to start it. Have fun, I'm keeping mine auto! I don't need another headache....
T
tarch
My 8V > 4V > 2V
3,073
Redmond, WA
Dec 3, 2004
  • Dec 3, 2004
i did it over summer break(1 week and 3 days (2.5 hours of goofing around/day))
here's a list off the top of my head:
tob
pilot bearing
transmission(duh)
transmission harness
crossmember
lower rubber shift boot
shifter
flywheel(depends if you have 8 or 6 bolt crank)
clutch
pressure plate
driveshaft
ecu
clutch/brake pedal assembly
clutch cable with the thingamathings for the firewall
i would sugest you check if your tranny still has the dustshield on the bottom of the tranny where the clutch cable goes in... you might need it
you need tranny oil
and i can't remember much more... good luck and you will love your car when it's done
Mach1Run
333
Wylie, Texas
Dec 3, 2004
  • Dec 3, 2004
make sure your 3650 tranny is one of the good one not the fubar ones some of us have.
K
TKX Transmission Shifting Problem
  • KWC156
  • Jun 23, 2025
  • Other Auto Tech
3K
Other Auto Tech Jun 13, 2026
427nostang
V6 to V8 Swap info
  • 02_2v_Curtis
  • Jan 11, 2026
1996 - 2004 SN95 Mustang -General/Talk- Oct 7, 2026
2v_johnny
New Member with a 1992
  • Clutchfork
  • Oct 18, 2025
  • The Welcome Wagon
The Welcome Wagon Oct 19, 2025
Clutchfork
Engine No start issue AGAIN!
  • ucnhtmenow1
  • Sep 1, 2024
SN95 4.6L Mustang Tech Sep 11, 2024
89ripper
H
Drivetrain 4R70W clutch friction/metals/piston set up questions for transmission guru
  • Hizdudeness
  • Apr 4, 2024
Fox 5.0 Mustang Tech Nov 15, 2024
slow84lx
