  • SN95 4.6L Mustang Tech
Transmission kickdown
  • Thread starter Thread starter Ram5773
  • Start date Start date Dec 6, 2006
R
Ram5773
66
Melbourne, Florida
Dec 6, 2006
  • Dec 6, 2006
I have a 02 GT that sometimes doesn't kickdown far enough when I think it should. What controls the kickdown points in our automatic transmissions? Trans pressure ?
Can someone explain how it works.
Thanks in advance
K
Kilgore Trout
Fried or Broiled ?
4,749
95
134
Dec 6, 2006
  • Dec 6, 2006
There is a lot of good info on the 4R70W here:
http://www.tccoa.com/articles/tranny/index.html
03ghoststang
Well-Known Member
Jul 16, 2005
1,930
Los Angeles, California
Dec 6, 2006
  • Dec 6, 2006
it electronically controlled if it senses the need to downshift it will otherwise it will stay in the current gear....
to original poster:
Have you done a trans flush recently????
R
Ram5773
66
Melbourne, Florida
Dec 6, 2006
  • Dec 6, 2006
I did a complete flush about a month ago, the trans fluid wasn't burnt it smelled fine and color was good. Sometimes my trans doesn't down shift to the lower gear when it will other times at the same speeds. Is something going out ???
I also have a tranny cooler that has been sitting in my garage for a month that I have not installed yet. I know I need to install it, work has been really busy.
Thanks for that site Kilgore:SNSign:
03ghoststang
Well-Known Member
Jul 16, 2005
1,930
Dec 6, 2006
  • Dec 6, 2006
it all depends on the load, if it senses it needs to downshift it will otherwise it wont
3,287
24
69
Broke
Dec 6, 2006
  • Dec 6, 2006
Do you have gears? If not get 4.10s and a tuner and itll be like a whole new car.
jeffnoel
1,638
Clovis, CA
Dec 7, 2006
  • Dec 7, 2006
Need more info like how fast your going and what gear it drops to when you put the pedal to the metal?
I also have an 02GT Auto basically stock and using a Predator to adjust the trans. If I'm going about 25mph in Drive (OD off) and punch it, it's kinda scary cuz it drops to 1st and will break traction with stock 3.27s.
DBMSTNG
I fantasize about it being BIG!
2,120
not quite here
Dec 7, 2006
  • Dec 7, 2006
the shift points are determined by mph and throttle position.
you can adjust them with handheld tuners.
Mustang II 4 cyl gear hunting and possibly messed up vacuum system
  • oesterreicher
  • May 31, 2026
1974 - 1978 Mustang II Talk & Tech Jun 14, 2026
manicmechanic007
M
85 Capri 5.0 transmission rattle
  • Mamaclean
  • May 2, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- May 17, 2026
Mamaclean
M
M
Idle control problems
  • miser143
  • Aug 28, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Aug 29, 2026
DadLife0724
2010 GT AC issue
  • 2010torchredgt
  • Jun 28, 2026
  • 2010 - 2014 Specific Tech
2010 - 2014 Specific Tech Jun 29, 2026
2010torchredgt
N
Vibration after new clutch
  • nipple_looker
  • Sep 20, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 26, 2026
fasterthangas
F
