I changed the fluid in my T3650 first with 3.2 quarts of Dexron III/Mecron combo since I couldn't find a straight Dexron III which I used last time with great results.
After the change when the car was cold and in 5th gear only the trans would make a metallic kind of noise where it almost sounds like wind coming in from the trans area. Or maybe like a slight metallic rattle. Its had to explain. If I put my foot on the clutch it would still be there. If I put it in neutral it would still be there. If I downshift into 4th it goes away. And when it warms up its fine in 5th.
So I figured I would try it again with some different fluid. So I went to the dealer and got the fluid they said they use which was a Motorcraft Mercon VI I believe. I put in 3.5 quarts and it still does the same thing. Any ideas?
