Transmission Problems
  • Thread starter Thread starter Coreyned
  • Start date Start date Nov 13, 2007
C
Coreyned
45
  • Nov 13, 2007
Hey guys so about 3-4 months ago i bought a 01 bullitt with a tranny problem. 3rd gear grinds when i try to shift into gear, all other gears sound crappy but go in, so im prerrt sure i need a new tranny. My gf ask'd her dad who knows about cars and he said to first change the hydraulic something, dont remember exactly what it was, and the clutch. and see if the tranny is any better. then if not go ahead and get another transmission. I just wanted to know your guy's thoughts about this, I probably need a new clutch anyways and rear end.. car was beat it seems like. but thanks for your thoughts.
joshjwc9
1,095
17
39
Palm Harbor, FL
Nov 13, 2007
  • Nov 13, 2007
It more than likely is the internals in the transmission. You probably need a new clutch too as grind the transmission isnt that good for the clutch either. Getting new synchros and forks and yadda yadda will allow you to shift it without grinding.
These transmissions are not operated hydraulically, they are cable operated, usually you would change out the fluid but that is not possible.
C
Coreyned
45
  • Nov 13, 2007
thanks for replying, but do you know where to get these forks and syncros, and how much do you think it would be? because I was thinking of buying a completely remanufactured tremec 3650 from this website i found for $800 after the core rebate. and comes with 6 months warranty i thought this was better for the price but how much would all the other items be?
joshjwc9
1,095
17
39
Palm Harbor, FL
Nov 13, 2007
  • Nov 13, 2007
D&D performance sells high quality stuff, thats better than stock, or you can always go to your ford dealer and price the stuff out.
Remember that your transmission has a recall or TSB, before you buy anything I would call the local ford dealer and they will run your vin # to see if they will replace it for free...there was a recall as the T3650 has many shifting issues in the early models made, just like in your Bullitt and other 01 GT's.
Good luck man!
F
ForPointSex
395
Mercer, NJ
Nov 14, 2007
  • Nov 14, 2007
I had the same problem. The 3rd gear synchro went bad. I bought a rebuilt one from http://www.smartpartsauto.com/manual_transmissions_mustang_tr3650_4014.htm
The shop charged me $300 to put it in.
Since your going to remove the tranny, change the clutch if you have a lot of miles.
I was also looking at the upgraded ones from http://www.promotionpowertrain.com/1231590.html
but I couldn't get ahold of anyone.
K
4r70w transmission problems
  • Kiddmustang
  • Jul 14, 2026
1996 - 2004 SN95 Mustang -General/Talk- Jul 21, 2026
squeak93
00 4.6L V8 new clutch won’t go into gear when on?
  • Timboslice
  • Aug 15, 2026
  • The Welcome Wagon
The Welcome Wagon Aug 21, 2026
Drivetrain Downshifting from 3rd to 2nd issue
  • Scott_S
  • Apr 23, 2026
Fox 5.0 Mustang Tech Oct 12, 2026
limp
P
2002 T5 transmission vibration issue
  • puffoo
  • Feb 22, 2026
  • SN95 V6 Mustang Tech
SN95 V6 Mustang Tech Feb 22, 2026
puffoo
P
W
Speedometer and shifting issues
  • wyatt-tetro891
  • Aug 17, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Aug 18, 2026
wyatt-tetro891
W
