- Nov 19, 2007
- 5
- 0
- 1
I have an 04 GT with the 3650. The car is grinding when it goes from 2nd to 3rd and if you try to downshift into 3rd it grinds really bad. But, when shifting from 2nd to 3rd, if i push the clutch in and put the shifter right infront of 3rd, let out of the clutch, push the clutch back in and shift into 3rd, it wont grind. 3rd gear is the only gear that grinds, Also, the clutch engages at the very end of the pedal and it feels like it might be slipping a little bit. Could this have anything to do with it? I need all the help i can get, thanks!
