Transmission questions..please help
crazyhorse89
30
Bay City, TX
I have an 89 GT, trans went out, found a manual trans from a 99 Mustang, six banger, will this tranny work on the swap, and if so what can i expect as far as drivebility, and performance issues/ please help with any info you all might have out there, thanks
im assuming your 89 was a manual already and you're just wondering if the 99 t5 will work in your car. if your 89 is an automatic, look up the t5 swap threads (a billion of them)
the 99 t5 will bolt right up, but you will need to go two different paths
1) (easier IMO) swap out the 99 input shaft for your fox input shaft
2) pick up a 94-95 v8 bellhousing, clutch assemly and driveshaft, your shifter will also be moved back in the car about 3/4 of an inch
the 99 v6 t5 is rated the same as factory v8 t5's, and everything else will bolt right up except for what is stated
good luck
Thanks alot ....... yes my 89 is a manual, the only thing that i had found out was that the gear ration was gonna be more higher, plus the speedometer cable would not go on the 99 t-5, other than that, we will be doing the swap in the morning, thanks for your input and help. :nice:
gear ratios are the same, only different one was the 4-cyl trannys in fox bodys
and yes the speedo won't hook up exactly, but i'm sure once you tear them apart you can see how to make it work
