dahun Founding Member Feb 18, 2002 102 0 0 California Dec 12, 2006 #1 Dec 12, 2006 #1 What are the gear ratios for the 2001 Gt manual transmission. Specifically, what's the over drive ratio? I know the '03s have a .62 ratio. Thanks, P
Stan Weiss Member Dec 8, 2006 347 2 16 Philadelphia, PA Dec 12, 2006 #2 Dec 12, 2006 #2 2000 GT and early 2001 is 3.37, 1.99, 1.33, 1.00, 0.67 for a T-45. In mid 2001 they changed the trans to the 3650.
mustangman9812 10 Year Member Jan 14, 2004 661 6 49 Mars Hill, NC Dec 12, 2006 #3 Dec 12, 2006 #3 T3650 Specs: 1st gear – 3.38 2nd gear – 2 3rd gear – 1.32 4th gear – 1 5th gear – .62 Reverse – 3.28
dahun Founding Member Feb 18, 2002 102 0 0 California Dec 13, 2006 #4 Dec 13, 2006 #4 Stan Weiss said: 2000 GT and early 2001 is 3.37, 1.99, 1.33, 1.00, 0.67 for a T-45. In mid 2001 they changed the trans to the 3650. Click to expand... I talked to a tech guy at Tremec and he seemed to think that the "2001" GT's had the 3650 and a higher 5th ratio of .67. He also said that they don't directly support these "ford" trannys but that I should get parts from directly...
Stan Weiss Member Dec 8, 2006 347 2 16 Philadelphia, PA Dec 13, 2006 #5 Dec 13, 2006 #5 Last year when I was looking to get a shift for my 2000 GT I checked many places. This link to the FORD shifter says M-7210-N # Fits 1983-01 Mustang with T-5 or T-45 transmission http://www.fordracingparts.com/parts/part_details.asp?PartKeyField=6723 The instructions show you how to tell if it is a 3650 http://www.fordracingparts.com/download/instructionsheets/FordInstShtM-7210-N.pdf
Mustang5L5 That is…until I whipped out my Bissell Mod Dude Feb 18, 2001 43,265 17,952 224 Massachusetts Dec 13, 2006 #6 Dec 13, 2006 #6 mustangman9812 said: T3650 Specs: 1st gear – 3.38 2nd gear – 2 3rd gear – 1.32 4th gear – 1 5th gear – .62 Reverse – 3.28 Click to expand... 2001-2002 T-3650's have a 0.67/0.68 5th gear In 2003 they went to the 0.62 which is the same ratio as 6th in the t-56 used in the Cobra
Mustang5L5 That is…until I whipped out my Bissell Mod Dude Feb 18, 2001 43,265 17,952 224 Massachusetts Dec 13, 2006 #7 Dec 13, 2006 #7 dahun said: I talked to a tech guy at Tremec and he seemed to think that the "2001" GT's had the 3650 and a higher 5th ratio of .67. : Click to expand... He is right Up til mid 2001, the trans was the T-45. Around mid 2001 they changed to the T-3650 with that 5th ratio In 2003, the t-3650 went to a 0.62 ratio
