Transmission swap
  • Thread starter Thread starter Cobain03
  • Start date Start date Apr 27, 2006
Cobain03
996
Lexington, Ky
Apr 27, 2006
  • Apr 27, 2006
my transmission is currently leaking from the front seal. i dont know why we didnt replace the seal while we had the engine out but to my question.
i currently have the stock 3 speed auto c4. is there an automatic overdrive (or at least a 4 speed tranny that would bolt right up?
jdowen2
48
Mesa, Az
Apr 27, 2006
  • Apr 27, 2006
You probably mean the AOD. You'll need a new driveshaft. I'm not sure if it's a bolt in but someone else here should know for sure.
302 coupe
1,952
Macon, Ga.
Apr 28, 2006
  • Apr 28, 2006
the seal only costs about $3, just replace it. It will take you a few hours to do it, but its not hard. IIRC, you're high school kid on a budget. Chances are, a properly executed AOD, T5, or other transmission swap will have your checkbook in the red zone. There's nothing wrong with a C4, they are great so long as you can do without the overdrive.
rbohm
6,698
550
204
tucson,az
Apr 28, 2006
  • Apr 28, 2006
302coupe has it right. unless you really want an AOD, you are better off replacing the seal. an AOD along with a new flexplate, driveshaft, modified crossmember, etc. is going to run you around $800 or so. that will buy alot of gas, so unless you need to od to cover for some deep rear gears, stay with the C4.
Sicarius428
2,085
Apr 28, 2006
  • Apr 28, 2006
Your C4 is stronger than the AOD anyways. The thousand dollars it would cost to change it over can buy you a lot of gas.
Kevin
Cobain03
996
Lexington, Ky
Apr 28, 2006
  • Apr 28, 2006
im not worried about making more power then the AOD will handle lol. maybe once i get on my feet, i'll do a t-5 swap or something.
i have a seal actually. it came with the rebuild kit lol.
N
nitequill
45
Los Angeles
Apr 29, 2006
  • Apr 29, 2006
not to steal the show guys... but i have a 351W that i forced into my 65 stang im using a stock 65-66 c4 and i wanted to know would it be a good idea to continue using the stock c4 or move on to something bigger?
rbohm
6,698
550
204
tucson,az
Apr 29, 2006
  • Apr 29, 2006
the C4 fits better than the AOD in the 65-66 cars. if you swap to an AOD you will likely have to massage the trans tunnel with a BFH. unless you are using 3.50 or lower gears, you dont need an overdrive unless you spend alot of time on the highway. in fact for a daily driver, and the 351w, you can use a 2.80 or 3.00 gear and never notice any real difference in performance at the seat of the pants.
Max Power
1,774
St Paul
Apr 30, 2006
  • Apr 30, 2006
I noticed a HUGE difference going from a 2.87 gear to a 3.50 on my 351.
A
Resolved 302 oil leak when running
  • AlexM556
  • Sep 8, 2026
Classic Mustang Specific Tech Nov 1, 2026
manicmechanic007
Ford truck engine swap issues
  • keel
  • Jul 7, 2026
  • Other Auto Tech
Other Auto Tech Jul 13, 2026
General karthief
D
1982 inline 6 needing help on transmission identification
  • Death_the_end
  • Sep 6, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 7, 2025
General karthief
F
Ford 460 swap
  • Ford460
  • Sep 13, 2026
Ford460
F
Mustang II 4 cyl gear hunting and possibly messed up vacuum system
  • oesterreicher
  • May 31, 2026
1974 - 1978 Mustang II Talk & Tech Jun 14, 2026
manicmechanic007
