Transmission woes
  • Thread starter Thread starter HiFlow5 0
  • Start date Start date Apr 28, 2005
First Prev 2 of 2
srothfuss
Last night I stabbed the same guy 7 times in a row
Oct 17, 2004
1,796
Woodward Ave.
Apr 30, 2005
#21
  • Apr 30, 2005
  • #21
squeeeg said:
T5's are designed to use ATF not synchromesh. Synchromesh is used for tremecs. I would recomend filling it up with synthetic ATF and seeing if that helps at all. My guess though is that you synchros are going out.
A T-5 needs ATF not Gear Oil or syncromesh! Start with putting the right fluid in there first. Better yet - you better flush out all the syncro crap before you put in the ATF. Then your trans will shift like it's supposed to.
HiFlow5 0
68
East Longmeadow, MA
Apr 30, 2005
#22
  • Apr 30, 2005
  • #22
I've read on other forums and I think here too that Syncromesh was supposed to be the best for T5's. If that's not the case, then I will promptly be putting in ATF. Is synthetic ATF better or worse, and how would I go about flushing out all the syncromesh completely?
old_blue
1,783
282
124
May 1, 2005
#23
  • May 1, 2005
  • #23
some people use synthetic and say it is smoother and they can feel it in the shifter. I used to have synthetic and noticed it a little but I also had a leak at the rear seal of the tranny so it I didnt notice the difference for long and I didnt like losing all that expensive fluid so I replaced the seal and ust run valvoline ATF.
First Prev 2 of 2
T
Drivetrain TREMEC TKX 1–2 Grinding Issue at ~4,000 Miles + Poor Warranty/Customer Service Experience
  • Ttopfoxguy
  • Oct 10, 2026
Fox 5.0 Mustang Tech Oct 15, 2026
JMG9350
J
Drivetrain Downshifting from 3rd to 2nd issue
  • Scott_S
  • Apr 23, 2026
Fox 5.0 Mustang Tech Oct 12, 2026
limp
Drivetrain How much resistance, if any at all, is normal on a new 1st gear and synchro on a WC T5 transmission?
  • sleep-e
  • Jan 21, 2026
Fox 5.0 Mustang Tech Jan 22, 2026
sleep-e
Drivetrain Broken clutch cable- what it looks like
  • JulianR
  • Aug 6, 2026
Fox 5.0 Mustang Tech Aug 10, 2026
gkomo
W
Speedometer and shifting issues
  • wyatt-tetro891
  • Aug 17, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Aug 18, 2026
wyatt-tetro891
W
