srothfuss
Last night I stabbed the same guy 7 times in a row
squeeeg said:T5's are designed to use ATF not synchromesh. Synchromesh is used for tremecs. I would recomend filling it up with synthetic ATF and seeing if that helps at all. My guess though is that you synchros are going out.
A T-5 needs ATF not Gear Oil or syncromesh! Start with putting the right fluid in there first. Better yet - you better flush out all the syncro crap before you put in the ATF. Then your trans will shift like it's supposed to.
