  • SN95 4.6L Mustang Tech
trany noise
  • Thread starter Thread starter zachdaniels
  • Start date Start date May 7, 2008
Z
zachdaniels
  • May 7, 2008
just put a new clutch in my 2002 gt & now im hearing a noise that sounds like a possible shaft bearing noise is gone when clutch is in all the way but is noticable when in gear at low rpm anyone have this i heard its common
40th GT
916
Lawrenceville, GA
May 7, 2008
  • May 7, 2008
I started hearing it after I installed my short shifter.
I suppose it's normal.
Z
zachdaniels
  • May 8, 2008
oil & water gauges
do you know where i can hook into my oil & water feeds to hook up my gauges
myponyrocks
I have more billet on the Stang than most women ha
Apr 18, 2004
1,219
May 8, 2008
  • May 8, 2008
prob a bad Throw Out Bearing.
They are hit or miss, even with the OEM Ford piece
*EDIT* For the gauges, it depends if they are mechanical or electric... theres a fairly cheap oil filter adapter ring if you search google good enough that makes the oil part cake.
Z
zachdaniels
  • May 8, 2008
throw out bearing is new i think its the input shaft bearing. gauges are electric
myponyrocks
Apr 18, 2004
1,219
May 8, 2008
  • May 8, 2008
Doesn't matter if the ToB is new, mines got less than 2k miles on it and it's going bad.
Just the nature of the beast from what I'm noticing. I'm on my 3rd clutch and only the 2nd one didn't squeak.
Maybe it's something else, but might as well check the cheapest option first
D
Loud noise(s) from Engine Bay
  • DuluthFoxbody
  • Oct 25, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Thursday at 3:50 PM
AeroCoupe
M
85 Capri 5.0 transmission rattle
  • Mamaclean
  • May 2, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- May 17, 2026
Mamaclean
M
N
Vibration after new clutch
  • nipple_looker
  • Sep 20, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 26, 2026
fasterthangas
F
2000 GT-Front Brakes Not Releasing
  • stormsedge
  • Aug 7, 2026
1996 - 2004 SN95 Mustang -General/Talk- Aug 7, 2026
Bronco2fan
00 4.6L V8 new clutch won’t go into gear when on?
  • Timboslice
  • Aug 15, 2026
  • The Welcome Wagon
The Welcome Wagon Aug 21, 2026
