just put a new clutch in my 2002 gt & now im hearing a noise that sounds like a possible shaft bearing noise is gone when clutch is in all the way but is noticable when in gear at low rpm anyone have this i heard its common
They are hit or miss, even with the OEM Ford piece
*EDIT* For the gauges, it depends if they are mechanical or electric... theres a fairly cheap oil filter adapter ring if you search google good enough that makes the oil part cake.
