Tremec 3550 Question
super302 said:
how much abuse can they take??
Can they withstand an occasional powershifting?
What is the first gear ratio? (compared to t5)
Thanks,
Patrick
They can take a lot of abuse. I have about 15 to 20 track passes on mine. Leaving at 6000 and Power shifting at 5800 everytime. I have not had any problems
TREMEC 3550
Standard
1st 3.27
2nd 1.98
3rd 1.34
4th 1.00
5th 0.68
6th N/A
rev 3.00
Tremec T-5
1st 3.35
2nd 1.99
3rd 1.33
4th 1.00
5th 0.68
6th N/A
rev 3.15
streetflossin said:
are you using the tko 500 or 600? is there anything special you need to do for the tko series or does it just bolt right in?
I have the older TKO. I bought it used from a dude on here. You need a 26 spline clutch disk (might as well buy a new clutch kit) a 31 spline yoke (might as well buy a 31 spline aluminum driveshaft) 3 quarts of GM syncromesh, new shifter, I think something has to be done to the xmember also, but after looking at mine, it doesn't look like anything was done to it. Get a new trans mount too. I didn't do the install. But I recently pulled my engine and trans so i'll be re-installing it this time myself.
